Knowledge Base Article
Critical Warning(25207): A programming file will not be generated because the assembler identified some pins have missing I/O Standard assignments. Refer to the I/O Assignment Warnings table in the fitter report for details.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3.1 and earlier, you might see this critical warning during the Assembler stage when assigning the I/O Standard to the negative differential pins of the Agilex® 5 FPGA devices and Agilex® 3 FPGA devices.
This is due to the I/O Standard of the negative differential pin is not reflected in the Quartus® .qsf file even though the I/O Standard had been assigned to the negative differential pin in the Pin Planner.
Resolution
To work around this problem, add the assignment below in the .qsf:
set_instance_assignment -name IO_STANDARD "<I/O_Standard>" -to "<negative_differential_pin_name>" -entity <entity_name>
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 7 months ago
Version 2.0
