Knowledge Base Article
Critical Warning (15003): "mixed_port_feed_through_mode" parameter of RAM atom dil:the_dil|dil_alt_vip_cl_dil_0:alt_vip_cl_dil_0|alt_vip_packet_writer:motion_writer|alt_vip_common_avalon_mm_bursting_master_fifo:master_fifo|alt_vip_common_general_fifo:.
Description
Critical Warning (15003): "mixed_port_feed_through_mode" parameter of RAM atom dil:the_dil|dil_alt_vip_cl_dil_0:alt_vip_cl_dil_0|alt_vip_packet_writer:motion_writer|alt_vip_common_avalon_mm_bursting_master_fifo:master_fifo|alt_vip_common_general_fifo:\write_used_gen:wdata_fifo|alt_vip_common_ram_fifo:\dual_clock_or_large_gen:ram_fifo|altsyncram:ram|altsyncram_3lr1:auto_generated|ram_block1a2 cannot have value "old" when different read and write clocks are used.
Due to a problem with the Intel® Arria® V Deinterlacer II IP in Intel® Quartus® Prime software version 15.0, you may observe the above warnings during compilation. These warnings can be safely ignored.
Resolution
This problem has been fixed in Quartus Prime software 15.1.
Updated 18 days ago
