Knowledge Base Article
Critical Warning: <corename>_if0_p0_pin_map.tcl: Failed to find PLL clock for pins if0|p0|controller_phy_inst|memphy_top_inst|afi_half_clk_reg
Description
When compiling your DDR2 SDRAM or DDR3 SDRAM UniPHY design in the Quartus® II Software version 11.0 or 11.0SP1, you may experience the following critical warning:
The critical warning does not occur on the first compile of the design but will occur on all subsequent compiles.
The cause of the problem is RAPID_RECOMPILE_MODE set to ON which causes the afi_half_clk_reg to not be preserved in subsequent compiles.
Resolution
The workaround is to delete the db directory before the design is re-compiled or disable rapid recompile in your project.
This issue will be fixed in a future version of the Quartus II software.
Updated 11 months ago
Version 3.0
