Knowledge Base Article
Couldn't open '/opt/Intel/OpenCL/Boards/a10_ref.fcd'
Description
When type ‘aocl install’ in Linux terminal, it will report "Couldn't open '/opt/Intel/OpenCL/Boards/a10_ref.fcd' for output
Unable to set up FCD. Please contact your board vendor or see section "Linking Your Host Application to the Khronos ICD Loader Library" of the Programming Guide for instructions on manual setup."
Resolution
When you aocl install, you must get root privilege.
[zhaojunz@OpenCL quartus_env]$ su
Password:
[root@OpenCL quartus_env]# aocl install
aocl install: Running install from /usr/local/intelFPGA_pro/17.0/hld/board/a10_ref/linux64/libexec
Looking for kernel source files in /lib/modules/2.6.32-573.el6.x86_64/build
Using kernel source files from  /lib/modules/2.6.32-573.el6.x86_64/build
Building driver for BSP with name a10_ref
make: Entering directory `/usr/src/kernels/2.6.32-573.el6.x86_64'
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci_queue.o
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci.o
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci_fileio.o
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci_dma.o
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci_pr.o
  CC [M]  /tmp/opencl_driver_iFFFg0/aclpci_cmd.o
In file included from /tmp/opencl_driver_iFFFg0/aclpci_cmd.c:53:
include/linux/aer.h:38: warning: \u2018struct pci_dev\u2019 declared inside parameter list
include/linux/aer.h:38: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/aer.h:39: warning: \u2018struct pci_dev\u2019 declared inside parameter list
include/linux/aer.h:40: warning: \u2018struct pci_dev\u2019 declared inside parameter list
include/linux/aer.h:57: warning: \u2018struct pci_dev\u2019 declared inside parameter list
 LD [M]  /tmp/opencl_driver_iFFFg0/aclpci_a10_ref_drv.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/opencl_driver_iFFFg0/aclpci_a10_ref_drv.mod.o
  LD [M]  /tmp/opencl_driver_iFFFg0/aclpci_a10_ref_drv.ko.unsigned
  NO SIGN [M] /tmp/opencl_driver_iFFFg0/aclpci_a10_ref_drv.ko
make: Leaving directory `/usr/src/kernels/2.6.32-573.el6.x86_64'
Updated 11 months ago
Version 3.0
