Knowledge Base Article
Configuration via Protocol (CvP) Implementation in Altera User Guide: Document Known Issue
Description
Issue 285006: Chapter 3 CvP Topologies, Version 2015.01.12
Figure 3-1, 3-2, 3-3, 3-4 and 3-5 show the pull-up resistor numbers for nSTATUS, nCONFIG, CONFDONE and CvP_CONFDONE as 10kw, but these should be 10k Ohm.
Resolution
This issue would be solved in the further document release.
Updated 1 month ago
