Knowledge Base Article
Compiler Error: Unrecognized function call: in OpenCL compilation with custom RTL code with Cyclone V Soc BSP
Description
Due to a problem in the Quartus® Prime software and Intel® FPGA SDK for OpenCL™ version 14.1 and later for  Cyclone V SoC platform, when integrating a custom RTL module into the OpenCL design, compile may fail with Cyclone® V SoC platform only for error below:-
Compiler Error: Unrecognized function call: acl.external.iowr.i1.si32.p4si32
Resolution
This problem has been fixed in the Quartus® Prime software and Intel® FPGA SDK for OpenCL™ version 17.0 for the Cyclone V SoC platform.
As a workaround, user can open up the cyclonev_tsm.xml file and add in the code below, this code is also available in the  Stratix® V platform.
  <!-- acl.external.iord callinst -->
  <group acl_intrinsic="acl.external.iord">
    <type base="any">
      <style name="default">
        <max-latency value="1"/>
        <min-capacity value="1"/>
      </style>
    </type>
  </group>
  <!-- acl.external.iowr callinst -->
  <group acl_intrinsic="acl.external.iowr">
    <type base="any">
      </style>
    </type>
  </group>
Updated 11 months ago
Version 3.0
