Knowledge Base Article
Can the GTS SDI II design example run on the Agilex® 5 FPGA E-Series Modular Development Kit, Revision C?
Description
The GTS SDI II IP Design Example User Guide: Agilex® 3 and Agilex® 5 FPGAs and SoCs describes how to compile and test the SDI II design example on hardware.
The instructions, including the Clock Controller GUI setup, are based on Revision B of the Agilex® 5 FPGA E-Series Modular Development Kit (MDK).
When using a Revision C board, some procedures may differ.
Resolution
To work around this problem, follow the steps written below.
The GTS SDI II IP Design Example User Guide is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Steps Migration Design to Modular Devkit REVC.
For GTS SDI II Modular Devkit (Parallel Loopback (with/without) external VCXO and Serial loopback Design)
- In sdi_ii_agi_demo.qsf
- Comment out all settings related to core_refclk_1485
- Change xcvr_refclk_1485 pin location from PIN_BC111 to PIN_AY120
- In sdi_ii_agi_demo.sv
- Comment out
// input core_refclk_1485, // 100 MHz default from Si5332 U412. Program OUT6-OUT8 to 148.5 MHz in Clock GUI.
- Change all connection core_refclk_1485 to clk_100mhz
- Comment out
- Open sdi_rx IP GUI
- Change Rx core clock (rx_coreclk) frequency to 100.0 MHz
- Click “Generate HDL” and save for regen IP with 100Mhz
- In sdi_ii_agi_demo.sdc
- Please remove Part 1
- Change Part 2 (core_refclk_1485) to clk_100mhz
For Parallel Loopback without external VCXO Design
- Change txpll_refclk from PIN_AV120 to PIN_AT120
For AXIS-VPP Full (Parallel Loopback (with/without) external VCXO) Design
- Open axi4s_iopll IP GUI
- Change Reference Clock Frequency to 100.0 MHz
- Click “Generate HDL” for regen the IP.
For Serial Loopback Design
For Serial Loopback (with Enable Dual Simplex) Design
- Change syspll_refclk from PIN_AY120 to PIN_BC111
- Open xcvr_ref_sysclk IP GUI
- Change Refclk frequency from 312.5MHz to 156.25MHz
- Click “Generate HDL” for regen IP
- Change the create_clock value of syspll_refclk from “135 MHz” to “156.25 MHz”
- Remove core_refclk_1484 create_clock settings
Clock Controller Settings for Agilex 5 FPGA E-Series 065B Modular Development Kit
- Set SI569 (U33) to 148.5MHz
- Set SI5391
- Go to si5391 folder, click on *.slabtimeproj to open ClockBuilder Pro GUI for settings the clock.
You may follow the Word document (SI5391_Configuratio_File_Generation_steps) to set the output clock and export a *.txt (register file) to import the clock settings. - On the SI5391 tab, set OUT1 to 141.00MHz and set the N-divider as Auto)
- Import the register.txt file into SI5391 Tab
- Click “Read” after Import completely, should be able to see SI5391 Tab OUT1 already been set to 141.0MHz.
- For Select Design = Parallel loopback without external VCXO, Open Clock Controller GUI, click the SI5391 tab, set OUT1 to 141.0 MHz.
- For Dynamic Tx Clock Switching = Tx PLL reference clock switching, Open Clock Controller GUI, click the SI5391 tab, set OUT1 to 148.3516MHz.
