Knowledge Base Article
Can I distribute the channels of an Agilex™ 5 FPGA LVDS SERDES IP in RX DPA-FIFO or Soft-CDR mode between two sub-banks?
Description
Yes, it is possible to distribute the channels between two sub-banks when using an Agilex™ 5 FPGA LVDS SERDES IP in RX DPA-FIFO or Soft-CDR mode. The channels need to be distributed across 5 or more bytes to use two sub-banks. The lowest 4 bytes used should be placed in one sub-bank, while the remaining bytes will be placed in the other sub-bank.
Resolution
When developing the pinout distribution and location of the channels of your Agilex™ 5 FPGA LVDS SERDES IP in RX DPA-FIFO or Soft-CDR, it is recommended to first validate them using the Interface Planner as well as Quartus® Prime Software Suite.
Updated 1 year ago
