Knowledge Base Article
Can I create false path constraints for paths contained in the file altpcie_reconfig_driver.sv?
Description
Yes, the three paths that you can false path in the Intel® Quartus® II software version 13.1 are:
- adce_off_r
- adce_on_rr
- resetpld_sync_r
The syntax below can be added to any SDC file in your project:
set_false_path -to [get_registers *|*.adce_off_r[0]]
set_false_path -to [get_registers *|*.adce_on_rr[0]]
set_false_path -to [get_registers *|reset_sync_pldclk_r[*]]
Resolution
This is fixed in Intel® Quartus® II version 14.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
