Knowledge Base Article
Can I connect unused GXB_REFCLK pins directly to GND in Cyclone® V GX devices?
Description
Yes, you can connect unused GXB_REFCLK pins directly to GND in Cyclone® V GX. This is indicated in the Cyclone® V Pin Connection Guidelines. However, a Quartus® II generated .pin file for this family indicates that an unused GXB_REFCLK pin should be connected to GXB_GND* (pulldown via a 10K ohm resistor).
Resolution
This is a bug in the Quartus® II software and will be fixed in a future release.
Updated 2 months ago
