Knowledge Base Article
Can I assert the transceiver tx_pma_elecidle signal indefinitely on Intel® Arria® 10 devices?
Description
No, you should not assert the transceiver tx_pma_elecidle signal indefinitely on Intel® Arria® 10 devices.
Resolution
The transceiver tx_pma_elecidle signal is similar to an analog reset signal. Asserting analog reset signals indefinitely can degrade transceiver performance. You can read about this degradation in the “Unused/Idle Clock Line Requirements” chapter of the Intel® Arria® 10 Transceiver PHY User Guide.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
