Knowledge Base Article
Arria10 CLKUSR pin IO standard and power
Description
CLKUSR is defined as a configuration pin, and it is a dual purpose I/O pins( dual-purpose I/O pins (DATA[0:31],CLKUSR, INIT_DONE, DEV_OE, and DEV_CLRn)).
When dual-purpose configuration pins are used for configuration, tie VCCIO of the bank to the same regulator as VCCPGM, ranging from 1.2V, 1.5V, or 1.8V.
so VCCIO of CLKUSR should be the same as VCCPGM when CLKUSR as configuration .
Updated 10 months ago
