Knowledge Base Article
Are there any known problems with rxvalid occasionally deasserting when the Rate Match FIFO performs a SKP insert operation when using Gen3 soft PIPE on Stratix® V GX devices?
Description
Yes, there is a known problem in PCI Express Gen3 soft PIPE where rxvalid is occasionally de-asserted when the Rate Match FIFO performs an SKP insertion on Stratix® V GX devices.
This issue is seen in systems that do not use a common reference clock. No issues are seen when a common clock is used.
Resolution
To workaround this issue, ignore the rxvalid signal during SKP insertion and instead use rxstatus on the PIPE interface to know when an SKP character is inserted (rxstatus = 001).
Updated 11 months ago
Version 3.0
