Knowledge Base Article
Are there any issues when performing dynamic reconfiguration using a mix of RX-only and duplex channels in Cyclone® V GX devices?
Description
Yes, you might see a Cyclone® V FPGA transceiver Avalon® Memory Mapped reconfiguration access hang when a mix of RX-only and duplex channel types share the same Reconfiguration intellectual property (IP).
Resolution
To work around this problem, install the Quartus II software version 13.1 Update 4, then download and install patch 4.43 from the following links:
Alternatively, you can install the Quartus® II software version 14.0.1.
Updated 4 months ago
Version 4.0
