Knowledge Base Article
Are there any differences in behavior between RTL simulation and hardware when implementing Rx CDR PLL dynamic reconfiguration using the direct write method of Stratix® V devices?
Description
Yes, you may see differences in behavior between RTL simulation and hardware when implementing Rx CDR PLL dynamic reconfiguration using the direct write method in Stratix® V devices.
Resolution
For RTL simulation, you may write the difference in the MIF file using the direct write method. For hardware, the entire Rx CDR PLL MIF file must be written.
Updated 11 months ago
Version 3.0
