Knowledge Base Article
AN 539: Test Methodology of Error Detection and Recovery using CRC in Altera FPGA Devices: Known Issue
Description
Issue 254634, Version 2014.12.15
The example .jam file shown in Example 5 contains the following syntax errors.
  1. Wrong double quotation character
    (“) and (”) are incorrectly used for double quotation. (") should be used instead.
    For example, in line 25, the example .jam file wrongly describes:
    PRINT “Error Type:”, out[45], out[44], out[43], out[42];
    It should be:
    PRINT "Error Type:", out[45], out[44], out[43], out[42];
  2. Semicolon (;) is missing in line 35
    The example .jam file wrongly describes:
    STATE IDLE
    It should be:
    STATE IDLE;
Resolution
When using the example .jam file from Example 5 in AN 539, replace all (“) and (”) with ("), and add a semicolon (;)  at the end of line 35.
Alternatively, download the revised .jam file from crc_inject_avcvsv.jam.
Updated 4 months ago
Version 5.0
