Knowledge Base Article
# ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: msimhdlmix; qhsimvl; or msimhdlsim # ** Error: (vsim-3039) ./..//AlteraTenGigMac.vhd(4743): Instantiation of 'altera_avalon_st_pipeline_stage'
Description
Due to missing encrypted Verilog library files, you may see the below error message when simulating a VHDL version of the 10Gb Ethernet MAC MegaCore® function generated in Quartus® II software version 13.0 using ModelSim®. This happens only with VHDL and not Verilog when you have a single language license of ModelSim.
# ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: msimhdlmix; qhsimvl; or msimhdlsim# ** Error: (vsim-3039) ./..//AlteraTenGigMac.vhd(4743): Instantiation of 'altera_avalon_st_pipeline_stage' failed.
Resolution
A patch is available to fix this problem in the Quartus® II software version 13.0. Download and install patch 0.22 from the appropriate link below:
This problem will be fixed in a future version of the Quartus® II software.
Updated 4 months ago
Version 4.0
