Knowledge Base Article
​​​​​​​Is there a known problem reading the temperature sensor channels from Agilex™ 7 devices when using the Configuration Debugger Tool?
Description
Yes, you may see the following error messages and not have the ability to read the temperature sensor channels in Agilex™ 7 devices when using the Configuration Debugger Tool in Quartus® Prime Pro Edition Software version 23.2 and later.
Error: Failed to read temperature sensor.
Error: All temperature sensor channels are currently inactive.
Resolution
This problem is fixed starting from Quartus® Prime Pro Edition software version 24.1.
Updated 11 months ago
Version 3.0
