Knowledge Base Article
“Failed to load client library” Message When Using USB Blaster with ARM DS-5
Description
If you try to debug the SoC HPS with the ARM DS-5 Development Studio over a USB Blaster, you might see a “Failed to load client library” message.
The Altera JTAG client library, required for debugging with DS-5 over the USB Blaster, links against a library which might not be found automatically. Although the Altera Complete Design Suite includes the required library, its containing directory is not included on the library path by DS-5 when the debugger starts.
Resolution
You can work around this issue by adding /linux to LD_LIBRARY_PATH before launching DS-5, with the following command:
sudo yum install libgomp.i686
Alternatively, upgrade to the SoC EDS v.14.1.
Updated 3 months ago
Version 2.0
