Wrong link for SOC Computer System v13.1 (ARM version of PDF)
Hello.
After a bit of browsing thru the FTP server with the UP materials, I've found out that, within the 14.1 subfolder, strangely enough, there is indeed a copy of the (alas) v13.1 PDF with "instructions/ description" for the ARM 9 stuff (versus Nios-II) of the Computer System, the PDF can be downloaded here:
and the corresponding FTP link e.g. for those using FileZilla or other direct clients would be:
I know they sometimes mix up versions within documentation when there have been no changes between the older version and a newer one, but in any case, Intel/ Altera staff should take more care with their website references to avoid us customers becoming crazy and spending our little time into these quirks rather than into our design work.
I know I am not alone in this, since I see a good bunch of posts dealing with broken/ wrong links all around.
Any gentleman/ lady from Intel Support / Doc staff can be nice to give us some reply/ insight? Are you fixing this? (since in his particular case, EVEN the UP Computer Systems installer/s for v13.1 does NOT populate the aforementioned PDF document.)
hi
if you don't have any quires, I'll close the case.
thanks & regards,
Hareesh.
