13 years agoWriting to SRAM from VHDL and using NIOS
Dear All, For a schoolproject I am working on a spectrum analyzer. I have downloaded the Altera University program and I modified de C code so it will display a nice coordinate system. Outside ...
13 years agoHow did you connect your component to the SRAM controller? If you do it in SOPC builder, you don't really have to care about the SRAM controller, or what kind of memory you are using. That's the big advantage of using Avalon memory mapped interfaces, your design can work with any kind of memory, as long as it is supported by SOPC builder.
Are you using SignalTap? You can use it to monitor your component and see what it is doing.
