15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
10 years agoHi guys,
m trying to replicate the results here. I believe im following all the correct steps, but when i run it, no text shows up in the nios console window. It downloads ok, but i get no errors, no messages, just a blank screen. Does anyone know what mght be causing that or what to check? I am not loading anything to flash memory. just programming the sof and the elf. never get to the code that says printf("\nSimple Socket Server starting up\n"); i dont think im getting past here: while (!iniche_net_ready) TK_SLEEP(1); and i get some kind of terminated exit value on the download inside the debug window? see attached The last thing that shows up on the console is listenng on port ... for connection from GDB, thats in debug mode. see attached Also, i dont get any complaints about mac address like this: "Can't read the MAC address from your board (this probably means that your flash was erased). We will assign you a MAC address and static network settings" One other thing: in the bsp editor, for the stdin,out,err, i dont have the option for "peripheral_subsystem_jtag_uart"... just jtag_uart. but i think thats ok as the qsys file just says jtag_uart. but this might be a reason i dont see any output on screen thanks
