15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
11 years ago --- Quote Start --- Hi all. I recently went through the exercise of getting the simple socket server to run on the DE2-115. The first guy who posted got it to work with version 10.1, I got it to work with Quartus 13.0 and the SBT for Eclipse. I had to make some slightly different modifications to the code to get it to work with the template that comes with 13.0, so I thought I would share it here. The entire process I went through is documented in the attached word document. The code is in the zip file. --- Quote End --- using hardware design attached with the tutorial on this link https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-net-std-de.html there is no hardware design related to DE2-115 I tried (niosii-ethernet-standard-3c120.zip ) related to Cyclone III, and I am facing a problem with pin assignment could you please help me thanks in advance
