15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
12 years ago --- Quote Start --- I am trying to get the most recent files (above this post) to work. Does the above example have the modification to code outlined in document already applied? I had to manually enter the CFI/EXT mod. So perhaps not? I am stuck at the: Can't read the MAC address from your board (this probably means that your flash was erased). We will assign you a MAC address and static network settings And don't seem to be getting anywhere copying the old code at the start of this thread either. Any pointers? --- Quote End --- Hi, I am too getting the same error, I have Quartus 12.0 edition & After downloading DE2_115_WEB_SERVER.sof I am trying to Download the application code (flash file system) for web server. But it gives the following error & asks to type the serial number. Actually I didn't find 9 digit serial number starting with ASJ on DE2115 board. Can anyone please help. --> Copyright 1996-2008 by InterNiche Technologies. All rights res prep_tse_mac 0 Can't read the MAC address from your board (this probably mean that your flash was erased). We will assign you a MAC address static network settings Please enter your 9-digit serial number. This is printed on a label under your Nios dev. board. The first 3 digits of the label are ASJ and the serial number follows this. -->Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3)
