15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
14 years agoGreat work on converting the example. Can you please post it up so I can update this thread.
In regards to your question re external access and IPs. I imagine you have to use features of your router to enable external access. I'm not knowledgable here at all so i suggest you google abouthome webserving. But I suppose you could use a port forward on your router. So your IP given to you by your ISP would be the IP and then the port your design uses would go with that. So you set your router to forward anything on that port to your boards local address. I have no idea if that would work, perhaps being a webpage you may not be able to select port. Again I obviously have no idea, sorry.
