15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
14 years agoHello, I managed to run the web server example and it works! However, I need to ask you if there is any way that I can send from FPGA to the webpage. In fact, using the webpage, I can write on the LCD, or light the leds ... What i need is the other way around, from fpga to the webpage.. And another thing is that the IP address assigned to the board and used to control the board remotely is local and I can only access it if I am within the domain of my router. What are my options if I want someone outside my router to have access to the board other than getting a real IP?
Help!!! Thank you!
