15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
14 years agoThanks!
Now the telnet server works. I am using a cross over cable and set the ip address, the subnet mask, and the gateway in windows manually. For the subnet mask and gateway, I used the values specified in the file simple_socket_server.h. I also had to turn off enable_dhcp_client as described in the file that you uploaded. So it was, as you said, a connection problem on the cable/computer side. The simple socket server is running on both evaluation boards, DE2 and DE4. Now I can start changing the socket server task to transfer data.
