15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
14 years ago --- Quote Start --- The telnet connection does not work, even though the board says that the socket server starts up correctly: ...a lot of messages including IP Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) --- Quote End --- That does look like the telnet connection should be working. Do you include the port number when you try to connect to it as in: 'telnet xxx.xxx.xxx.xxx 30' ??? It won't connect without the port number 30 after the IP address. It would help to see the rest of the messages. Also,
- Is your ethernet connection through a router?
- Are you using DHCP? If so, is it acquiring an IP address from the router or defaulting to the static IP?
- When it's negotiating with the MAC and PHY, does it succeed or fail? I've seen it fail the negotiation at times, but still fall through to the 'Simple Socket Server listening on port 30' as though everything is working. That's not good, and it won't work that way.
