15 years agoWORKING: DE2-115 Simple Socket Server
Hi, It seems difficult to get help on these forums so I want to pass on what i learnt for others. I've struggled to learn FPGAs over the past few weeks and I have finally got a simple socket s...
14 years ago --- Quote Start --- How should I approach building a socket server? --- Quote End --- Download the example files appropriate to your system from the nios ii ethernet standard design example
Located at http://www.altera.com/support/examples/nios2/exm-net-std-de.html (http://www.altera.com/support/examples/nios2/exm-net-std-de.html) Then follow my modified procedure as outlined in the attached PDF file. This is the best example of the Simple Socket Server that I have found. It still requires some tweaking for your specific system, but it does work when all the planets are alined correctly...
