16 years agowm8731 AUDIO codec
Help !!!, Does anyone how to use the audio codec on 8731 with vhdl and without NIOS processor ? help me please, I need to generate a single tones with this codec.......:confused:
16 years agoCopy from a post of user trieutan ( my old nick :cool: )
ROM= 16'h0c00; //power down
ROM= 16'h0ec2; //master
ROM= 16'h0838; //sound select
ROM= 16'h1000; //mclk
ROM= 16'h0017; //
ROM= 16'h0217; //
ROM= {8'h04,1'b0,vol}; //
ROM= {8'h06,1'b0,vol}; //sound vol
//ROM= 16'h1e00; //reset
ROM= 16'h1201;//active
First and foremost you should understand the software control interface (using I2C). one write sequence require 3 bytes : 7-bit slave address ( 0x34 ), 1write bit ( 0 ), 7-bit register address, followed by 9-bit data. at page 46 of the datasheet, you could find Table 29:Mapping of Program Registers ROM[0]= 16'h0c00; //power down , R6 : enable power for all modules ROM[1]= 16'h0ec2; //master R7: used inverted BCLK, Master mode, I2S format, MSB-first left-1 justified I believe you could easily understand the rest of the configuration. After configuring WM8731, you need to activate it by this one ROM[`rom_size]= 16'h1201;//active btw, For the I2sound demonstration WM8731 is configured in the sidetone mode ( directly route from mic to headphone ). If you want to make the codec speak audio from PCM like wav file, you probably want to see the configuration in SDcard to music demonstration.
