PKoor
6 years agoWhy is the FPGA Monitor Program Editor (from the UPDS) disabled/not working?
Freshly installed on Windows10 with Quartus Prime 18.1, the intel FPGA Monitor Program built-in Editor (and "Project Files") are disabled from the "Windows" menu (grayed-out). The symptoms are simila...
EBERLAZARE_I_Intel
6 years agoHi Paul,
I apologize for the late response, as I just got the notification.
The editor will be disabled during the debug session, and re-enabled when the debug session is exited
The source level debugging feature of the Monitor Program is a beta feature in the current release. The feature can be enabled and disabled at any point by going to the Edit menu and selecting Edit > Enable Source Level Debugging, or Edit > Disable Source Level Debugging, depending on whether the feature is currently disabled or enabled respectively.
Regards.
