MDavi68
6 years agoWhy fpga_crossgen is given an error "aocl-clang-9: error: cannot specify -o when generating multiple output file" using Version 19.3?
Hello, I am testing fpga_crossgen to develop libraries from *.cpp to OpenCL. I am following the example "OpenCL Matrix Multiplication Hierarchical Library" , i++ compilation is ok, but in the step...
MEIYAN_L_Intel
6 years agoHi,
Since you are using the OpenCL source code to create library object, according to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf in chapter 10.1.1.1, you may need to use command as below:
fpga_crossgen --target target_HLD_tool [-o ]
