SSchneider's avatar
SSchneider
6 years ago
VWF Simulation error with Quartus Prime 20.1
I fixed my first error message by manually removing the "vsim -novopt -c -t 1ps -L ..." line, however, now I am getting the generic error message below. Any thoughts? Thanks in advance for any suggestions..
# do Full_Adder.do
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim - Intel FPGA Edition vlog 2020.1 Compiler 2020.02 Feb 28 2020
# Start time: 13:03:12 on Sep 21,2020
# vlog -work work Full_Adder.vo
# -- Compiling module Full_Adder
# Top level modules:
# Full_Adder
# End time: 13:03:12 on Sep 21,2020, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vlog -work work Waveform1.vwf.vt
# -- Compiling module Full_Adder_vlg_vec_tst
# Full_Adder_vlg_vec_tst
# Executing ONERROR command at macro ./Full_Adder.do line 5
Error.
    • RichardT_altera's avatar
      RichardT_altera
      We do not receive any response from you to the previous question/reply/answer that I have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
      Shyan Yew
      • SSchneider's avatar
        SSchneider
        I was able to fix he error by only deleting the "-novopt" command from the "vsim -novopt -c -t 1ps -L ..." line in the simulation configuration. I originally deleted the whole line which got rid of the first "novopt" error, however, it caused the second generic error.
