16 years agoVibrato(FM) effect on DE2
Hi, i'm trying to create effect like vibratto, flanger. Simply frequency modulation. My sampling for audio is 48khz As far as i know it can be done using circular buffer(variable delay to modify phas...
16 years agothe example from the link is very simple, it doesn't require reading from RAM twice for every sample
you will take the variable-length delay you've already written. register the output of the delay (register again if you are already registering it once). then sum the output of the delay and the registered output in a first test you could leave out the (n) and (1-n) multipliers and just let the signal grow, and send the most significant portion of the output word to the DAC. next you could add the multipliers in and experiment with fixed values or maybe even some kind of real-time control. MIDI is pretty easy to add
