16 years agoVibrato(FM) effect on DE2
Hi, i'm trying to create effect like vibratto, flanger. Simply frequency modulation. My sampling for audio is 48khz As far as i know it can be done using circular buffer(variable delay to modify phas...
16 years agoThanks thepancake, my main problem was that i was writing and reading from address pointer based on mod signal. now when i am writing sequentialy from 0 to 720 and back fromo 0 to... It is working, and awfull noise from as you said discontinuities appears.
The thing is i realy don't know how to interpolate it. you know, this should be only small delay, so 720 is max delay. When accumulating address on every lrck i get 720 very fast. And modulation wave will is to slow if you know whan i mean :) Another problem.... Whole life full of problems :/
