Wcheekei
3 years agoVHDL code for JK flip-flop issue
Hi, I'm having issue trying to understand the code generated by the software Intel Quartus Prime. The JK flip-flop block used has an IF-ELSE statement that conflicts with each other. The SYNTHESIZED...
- 3 years agoHello,
synthesized code is often not well readable. The strange SYNTHESIZED_WIRE_2 coding is produced by connecting set and reset inputs together in your schematic input. Nevertheless it's logically correct.
Most recent FPGA families don't support simultaneous usage of asynchronous set and reset, you should avoid it in code intended for FPGA synthesis.
RichardT_altera
3 years agoYes, he is right. To add-on, asynchronous set and reset signals are not synchronized to the clock and can introduce timing hazards and metastability issues. The simultaneous use of asynchronous set and reset signals in a flip-flop can lead to race conditions, data instability, and unpredictable behavior, making it difficult to meet timing requirements and ensure reliable operation.
You may checkout this document for further details.
We recommend that users to follow the Synchronous FPGA Design Practices.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey
