Wcheekei
3 years agoVHDL code for JK flip-flop issue
Hi, I'm having issue trying to understand the code generated by the software Intel Quartus Prime. The JK flip-flop block used has an IF-ELSE statement that conflicts with each other. The SYNTHESIZED...
- 3 years agoHello,
synthesized code is often not well readable. The strange SYNTHESIZED_WIRE_2 coding is produced by connecting set and reset inputs together in your schematic input. Nevertheless it's logically correct.
Most recent FPGA families don't support simultaneous usage of asynchronous set and reset, you should avoid it in code intended for FPGA synthesis.
FvM
3 years agoHello,
