18 years agoVGA VHDL DE2 problem
Hi, I'm currently trying to use the VGA capabilities of the ALTERA DE2 board to display a red screen with VHDL. The resolution i'm using is 640x480. I've written a code for it but it doesn't wo...
17 years ago --- Quote Start --- I attached a working 640x480 driver for debug / comparison. If the timing is off the nicer LCD monitors will just reject the signal. It can be helpful to plug it into an older CRT to get more information about what went wrong. --- Quote End --- Should this code put anything out on the VGA or is it just a driver. Sorry im confused!?:confused:
