17 years agoVGA to NTSC converter
Hello good evening I would like if possible, someone would post an example in using the Verilog converter "NTSC" to "vga". That is, I would like to connect a camera at the entrance RCA "video ...
14 years agoHello, I have to use the RGB signals for another purpose, so i divide the demonstrator in two blocks, one that generate the RGB signals and other that put it in the VGA output.
I didnt change the code, but some vertical lines are appearing over the video. Anyone knows why? thank you! Eze
