17 years agoVGA to NTSC converter
Hello good evening I would like if possible, someone would post an example in using the Verilog converter "NTSC" to "vga". That is, I would like to connect a camera at the entrance RCA "video ...
16 years agoHello Jovander,
Why dont used the code provided together with DE2-70 board, DE2-70 TV demo? NTSC, camera with TV out, u can streaming the video at VGA. If u have the original code, I figure there is some problem. If u want to make it work, u have to change this. // Turn On TV Decoder assign oTD1_RESET_N = 1'b1;(Uncomment this one, ori this disable) //assign oTD2_RESET_N = 1'b1;(Comment this one, original this one enable) // Set SD Card to SD Mode assign SD_DAT3 = 1'b1; // Enable TV Decoder //assign oTD1_RESET_N = iKEY[0];(comment this part, just disable) I hope it will help u. C ya...
