13 years agoVGA resolution problem
Hello all, I am using the University program media computer and this works. As I see how it is set up the VGA pixel buffer is 320x240 and then it's scaled to 640x480. But I want to ha...
13 years agoAt the moment I hook up the pixelbuffer to the resampler then to the scaler, which is hooked to the alpha blender and then to the controller.
When I remove the scaler I set the resolution of the pixelbuffer to 640x480 but I suppose that's where the culprit is. I can then only write about half of the screen, the bottom half is then a repeat of the top (indicating an overflow with reading the memory perhaps?). I checked again today through the documentation but it doesn't anywhere mention that I can write to a 640x480 buffer, so I guess no luck with the IP cores.
