14 years agoVGA problem
Hi, Anyone here can help me with VGA problem, the program code just simply output one colour to monitor. However, my monitor display nothing. I have no idea what happen. :( The attachment is my...
14 years agoHello,
Thanks for the reply and the manual, it helps me a lot ! I think the polarity is correct because I was able to run the DE2_TV example from the DE2 CD. The monitor I used was the old CRT and the clock I had tried were 25MHz and 25.2MHz. Other than that, the timing I used was: // Horizontal Parameter ( Pixel ) parameter H_SYNC_CYC = 96; parameter H_SYNC_BACK = 48; parameter H_SYNC_ACT = 640; parameter H_SYNC_FRONT = 16; parameter H_SYNC_TOTAL = 800; // Virtical parameter ( Line ) parameter V_SYNC_CYC = 2; parameter V_SYNC_BACK = 32; parameter V_SYNC_ACT = 480; parameter V_SYNC_FRONT = 11; parameter V_SYNC_TOTAL = 525; The problem seem like the monitor did not turn on after downloading the program. I afraid my code got problem. I hope there got any simple VGA verilog code example that I can refer. Thanks ! Best Regards, TWK
