16 years agoVGA_CLK Pin on DE1?
Hi All, We are using the UP VGA Core. Can someone tell us where's the pin location for VGA_CLK on DE1? It is not found in the DE1 Assignment Spreadsheet. For DE2, it is B8 but we are not sure w...
16 years agoHi Peli,
We are actually using the core in the SOPC system and used the External Clock module to generate the 25 MHz VGA Clock. The problem is we can't access the VGA core after it has been integrated into the SOPC system. I suspect that will be the case even if we are using a PLL. Please correct me if I am wrong. Thanks for your comments. Dennis
