Verilog FSM stuck on one State forever
- 1 year ago
You have nextstate in your case statement, but state never updates to nextstate.
Fix it by adding a sequential block to update state at every clock edge.
always @(posedge clk) begin
if (~rst)
state <= idle;
else
state <= nextstate;
endI would recommend to checkout 'Two Always Block FSM coding style' from the article below.
It uses two separate always blocks:
- State Register Block: A sequential (always_ff ) block that updates the current state (state_reg) on the clock edge.
- Next State & Output Logic Block: A combinational (always_comb) block that determines the next state and the outputs based on the current state and inputs.
http://www.sunburst-design.com/papers/CummingsSNUG2019SV_FSM1.pdf
Richard Tan
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
