snehalatha
2 years agoVerilog code for serial communication protocols without Nios II processor
hello sir! can you share the Verilog codes for serial communication protocols without using Nois II processor in the Quartus prime lite application and along with pin assignments and output?
SyafieqS
2 years agoThere is no template Verilog for serial communication, we used IP that is integrated in Qsys, generated to HDL.
You can use that way.
- snehalatha2 years ago
Thanks for your replay!!!
Can we implement UART with Avalon mm interface without Nios II or any other processors??
