14 years agoVerilog code for a clock
I'm new to writing code. I'm currently working on code for a clock... a pretty standard homework application for students I know. I've been trying to teach myself verilog for sometime now, and I coul...
14 years agoHave you simulated your design? If you have, you would easily see the problem.
I can't match your code with what you describe. As I understand, CLK is the hour clock, and you want to use this clock to count from 0 to 12 in a BCD sequence and display the result on two 7-segment LEDs as the hour, right? I would do it as the following: module decimal_counter_20(A,B,CLK,RST); input CLK, RST; output [3:0] A; // suppose A is the higher digit of hour counter output [3:0] B; // suppose B is the lower digit of hour counter reg [4:0] C; // hour counter from 0 ("00000")to 12 ("10010") in BCD sequence always @ (posedge CLK or negedge RST) if (~RST) C <= 5'b00000; else if (C == 5'b10010)// count to 12, reset to 0 C <= 5'b00000; else if(C[3:0] == 4'b1001) //when lower digit reaches 9 begin C[3:0] <= 4'b0000; //lower digit resets to 0 C[4] <= 1'b1; //higher digit becomes 1 end else C[3:0] <= C[3:0] + 4'b1; // increase by 1 //assign the lower digit of counter to B assign B = C[3:0]; //A can only be either 0 or 1, so A[3:1] are always 0 assign A[0] = C[4]; assign A[3:1] = 3'b000; endmodule
