11 years agoUsing TSE MAC+ 88e1111 PHY on De2i 150 board to send data between FPGA and PC
Hello everyone: I'm now trying to use TSE MAC+ 88e1111 PHY on De2i 150 board to send data between FPGA and PC,which needs run at a speed at least 200Mbps. Firstly,I used Terasic's Websever ...
11 years agoHi,
I will try to help you, but first please list your used FPGA, the board (I assume it is the DE2-115 from Terasic) and the used software version. Did you run the example project? Did it work? If you have not done that, can you please test that first? I am asking for this because I would do exactly the same, before starting to modify it. As soon as I know if that is the board you are using I can give it a try myself. Cheers,
