13 years agoUsing rs232 HAL in Nios II IDE
Hello, I hope someone could give me a hint to unblock my situation: I have troubles in using HAL for university program RS232 in Nios2 IDE. I included "altera_up_avalon_rs232.h", I spent days ...
13 years ago --- Quote Start --- Hello! I'm have the same doubt... Im using the altera RS232 university program, and I use the functions described in the datasheet of the RS232 core. I was trying to send some data with nios 2 to the rs232... but I could't get any success yet. Here's the code: # include <stdio.h># include <system.h># include <string.h># include <stdlib.h># include <unistd.h># include "altera_up_avalon_rs232.h"; int main() { int c; printf("\033[2J"); //clean screen printf(" Start.\n"); alt_u8 data; unsigned int space; alt_u8 temp; alt_u8 RS232_dev; data = 2; //just some data to send... RS232_dev = alt_up_rs232_open_dev (RS232_NAME); space = alt_up_rs232_get_available_space_in_write_FIFO(RS232_dev); printf("%d\n", space); while (1) { temp = alt_up_rs232_write_data(RS232_dev, data); printf("%d", temp); //if temp is =0, the data was send... for(c=1; c<=100000; c++) //delay {} } return 0; } The function "alt_up_rs232_write_data" is returning "0", that means success... but I'm geting nothing through RS232, which I'm reading with a software (like Hyperterminal) in a computer. Link to the datasheet of the RS232 core: ftp://ftp.altera.com/up/pub/altera_material/11.1/university_program_ip_cores/communications/rs232.pdf Thanks! --- Quote End --- This is my test code, a simple program to test the NIOSII functionality. It works, the only problem is that my terminal (Teraterm) shows strange delays and crashes very often. Anyway the RS232 works: # include "sys/alt_stdio.h"# include "alt_types.h"# include "system.h"# include "altera_up_avalon_rs232.h"# include "altera_avalon_pio_regs.h"# define CLOCK_MHz 27 static void delay_us(int us); int i; int times; alt_u16 sw; alt_u8 data; alt_u8 error; int e; /**************INITIAL MESSAGE*************/ static void initial_message() { alt_putstr("\n*****************************\n"); alt_putstr("* Hello from Nios II! *\n"); alt_putstr("*****************************\n"); } /****************DELAY*********************/ static void delay_us(int us) { times=CLOCK_MHz*us; for(i=0;i<times;i++){;} } /*****************MAIN**********************/ int main() { initial_message(); alt_up_rs232_dev* serialPort = alt_up_rs232_open_dev(RS232_0_NAME); delay_us(100); while(1) { sw=IORD_ALTERA_AVALON_PIO_DATA(PIO_SWITCHES_BASE); IOWR_ALTERA_AVALON_PIO_DATA(PIO_LEDR_BASE,sw); e=alt_up_rs232_read_data(serialPort, &data, &error); delay_us(1000); e=alt_up_rs232_write_data(serialPort, data ); } } Try with another terminal and be shure to set the right configuration.
