18 years agoUsing LCD on DE2
Hi. I know a lot of post are about lcd and de2 but i have some problems.
In fact, i use the 3 files in my project: altera_avalon_lcd_16207.c altera_avalon_lcd_16207.h altera_avalon_lcd_16207_regs.h (i have attached them in txt so you can check it). The problem is: I'm not very good at c language and I was wondering if someone can write me a small code that uses functions of altera_avalon_lcd_16207.c to control the LCD. Thanks PS: I use a NIOSII and NIOS IDE1 Reply
Hi.
In "DE2_demonstrations\DE2_NET\hello_led_0" look for LCD.C file. There you have an example. It's: --- Quote Start --- void LCD_Test() { char Text1[16] = "Altera DE2 Board"; char Text2[16] = "Ethernet Testing"; // Initial LCD LCD_Init(); // Show Text to LCD LCD_Show_Text(Text1); //This show the above text 1st line // Change Line2 LCD_Line2(); // Show Text to LCD LCD_Show_Text(Text2); //This show the above text 2nd line } --- Quote End ---
