18 years agoUsing DE2 board with Quartus and NIOS IDE Version 8
Hello, I've installed Quartus Version 8 and NIOS IDE Version 8 after using Version 7 for some time. With version 7, there was no problem in using the DE2 board with NIOS IDE - everything worked...
18 years ago --- Quote Start --- Did you try re-generating (and compiling) the SOPC system and then compiling and using your old projects? Simply importing old projects in the new version without recompiling the SOPC system will not work. --- Quote End --- No. I opened the system with SOPC builder version 8 and got a lot of messages that system parts were automatically replaced. A Generate was possible. However, I did not compile the generated system since I assumed that the pin assignments were lost and it would be a tedious and error-prone work to reassign all. I simply hoped that the HAL provided with NIOS IDE version 8 would work with the hardware generated with version 7.2. Now, with your help, I know that I have the choice either to use the old version (7.2) or to recreate the hardware including assignment of pins.
